Re: Mercury Jet Drive Pump Adjustments
You'll need a set of long feeler guages.
The impeller clearance is generally set to .020 from the outer edge of the impeller to the replacable liner.
This is done by moving shims from one side of the impeller to the other, increasing shims behind the impeller close the clearance to the liner, moving shims from the backside to under the retaining nut increases clearance.
Watch WOT RPM, you can 'fine tune' impeller clearance to match engine performance/power output, increase clearance to raise WOT RPM, and decrease clearance to lower RPM.
Merc pumps are a carbon copy of (insert brain fade here)
I'll have to repost tomorrow from work with their name and number, you can order a parts and service manual identical to your pump.
