Ok, I am an extreme newbie at this but here goes. I've got a 50 HP 2 cylce evinrude with an oil reservoir, and it will not idle all the time. Here's what I've noticed -
No matter how many times I press the primer bulb it doesn't get hard. It remains soft. If I raise the idle speed from the shifter I can get it to start, but it barely idles for a few minutes and then after running for a few moments it will pick up speed to a fast idle. When I depress the fast idle it eventually dies. If by some chance I get it into gear - I can take it all the way up to full throttle and it runs great, but once I bring that to low speed it will eventually die.
I'm thinking about replacing the tank, bulb, and fuel hose to the motor as a start - any thoughts? Thanks in advance.
