evinrude identification
boatmen
I have an 65 hp evinrude can't find model # anywhere, has been rubbed down on transom mount no # on welch plug on engine, do have serial # but doesn't do much good how can I find out what year I have. Motor is electric shift with a johnson contol lever.
mrfixitman40
Re: evinrude identification
if you give the model number someone might be able to help you on here they are very knowledgeable
boatmen
There in lies my problem can't find any model # just a serial # that doesn't do any good.
F_R
So you have the serial #? What is it? On some, the model is the first characters of the serial #.
The 3-cylinder 65hp with Hydro-Electric shift was only made in 1972. The 1973 had power shift and the 1971 was 60hp.
boatmen
The serial# is J0001505 model # was on same plate but can't read it anymore, the boat is a 1986 but I'm sure the engine isn't that new. I've had some people tell me that because it has a J begining serial # that is a Johnson. but my buddy has a evinrude 70 hp and his serial # also begins with a J when Johnson took over evinrude from what I can tell all evinrudes have a J in the serial #. So from what you said they only made the Hydro Electric Drive in 72 it has to be a 1972 motor.
F_R
The J in the serial number means it was assembled at the Johnson plant in Waukegan IL. That means very little from a practical standpoint because a lot of Johnsons were also made at the Evinrude plant in Milwaukee. AND both were also made all over the world.
BTW, Johnson did not "take over Evinrude". If anything it was the other way around when back around 1936 Ole Evinrude's Elto and Evinrude and Lockwood, collectivly called Outboard Motors Corporation acquired Johnson and formed OMC --Outboard Marine Corporation.
