fishanator
Thread starter- Joined
- Sep 4, 2007
- 5
I am at wicks end with this motor!!! I tried everything- the heat exchanger, manifold and thermostat. I had the water pump on the out drive changed this past winter. Water flows through every hose I take off. Over heats when moving and idle. Cools down when I bring it up in rpm's not in gear. Checked plugs and oil, no water or signs of water. Seems to be a slight knock in front end of motor. Could this be a timing matter. This is a 1981, and it's in a 20' grady white w/a. Please any input will help. thank-you.
