erikgreen
Thread starter- Joined
- Jan 8, 2007
- 3,105
Re: My rapido longblock (pics)
I've been trying to get some help from my friends to come over and install, but everyone's busy. Looks like I'll be doing it myself on either saturday or Sunday, solo.
A couple little things have been done.
I have re-installed the transom in my boat, getting it ready to put the engine in. I had to install a new seal O-ring on the outer part (gimble base) and I installed new zincs (acorns) and bolts on the bottom. It took a while to figure out and correct the wire, hose, and cable routing.
I had to work on the bell housing/gimble base outer seal so I could put the new O-ring on... it was pretty corroded, so we wire brushed it and I attached the seal O-ring semi-permanently using a little 3m 4200 on the housing side, so that side is sealed, and I'll rely on pressure from the bolts to seal to the outer transom gelcoat. I did give it a quick once over with 600 grit sandpaper to make sure there weren't any bumps in the gelcoat.
I'm going to try to mount the motor myself as I stated, but I redid the motor mounts in the boat (rot plus broken bolts in them) so I will be mounting the motor, aligning it, drilling holes for the lag bolts, sealing the bolts in place, then running the motor's cam break-in.
I have read in other places on this board the break-in procedure, so I'm planning on starting it, running it up to 2k rpm for an hour, then doing an oil and filter change. I'll also be pre-running the oil pump with a drill before start, and I'll probably use a portable fuel tank for gas to make sure I have good fresh fuel for the break-in.
I also installed new plugs and belts as part of the build finishing, and I'll be putting a new distributor cap and rotor on before the break-in too.
More news soon,
Erik
More news soon,
Erik
