threecaster
Thread starter- Joined
- Sep 6, 2007
- 3
Greetings all!
I have been (un?) lucky enough to have been given a 1962? West-Bend Commodore, 2 stroke, 2 cyl, 18 hp outboard motor.
I have lots of experience with garden variety engines, but this is my first Outboard motor.
After much research, some TLC, some tweaking, and lots of cleaning, I have
gotten it to run!
Well, at least sort of.
I'm running a 24:1 mix for fuel.
I am still trying to get the needle valves adjusted. In doing so, several questions have come to mind.
#1) I am running it in a test tank (aka 40 gal trashcan) with no prop. Will this hurt anything?
#2) Can I adjust the throttle effectively with it in a "no load" condition?
I performed an inspection on the impeller, which seems fairly new (black rubber shiny, no cracks, has all its legs with the little knobs on the ends) but it seems that not a whole lot of water is coming from the exhaust port.
#3) How much water should I be seeing?
#4) How hot is too hot?
The manual (thanks to Noyes Trading Co. on ebay) says "18 O.B.C. Certified Brake H.P. at 4750 R.P.M."
#5) Does this mean 4750 is the Maximum RPM?
#6) What kind of a device is best to measure RPM on such a beastie?
(I have considered taping 4 magnets to the flywheel, using a reed relay and using my Sears Tak-0-meter, set on "4cyl"...but......)
On the Tiller Handle is the throttle controller, which is labeled "Fast - Start - Shift - Stop". I have a F-N-R gear knob on the main body.
#7) What is supposed to happen when the throttle is in the "Shift" position?
FYI: the shaft still turns even when in neutral, but can be stopped by hand (but NOT while running...I'm crazy...not stupid!
Even in Neutral, it churns up a lot of water, even without a prop.
O.K....I've pestered everyone with enough questions for now.
If anyone can help me even with a few of these....that would be fantastic!
Tanks! ...er...Thanks!
Threecaster
gotten it to run!
Threecaster
