Thread starter- Joined
- Sep 22, 2003
- 28,772
Re: Outboard Fuel Economy Study
BF -- these are three identical boats with three different engines, and a fourth boat that is very similar and a fourth different engine (selected only because that engine was not tested on the same boat as the other three). You simply cannot compare fuel economy in cars with boats for what should be very obvious reasons. Slippage and resistance are just two. And you like others, continue to use the word "efficiency" and "economy" erroneously. I also explained those terms earlier. No -- I am not leaning toward any brands or technology here. In fact today one is hard pressed to find an engine that is not fuel injected (for the same reason a car is by the way). And the primary reason is emissions, and secondary is economy at mid and slower speeds under certain conditions. Heck, I've been a Johnson/Evinrude person all my life and my current boat is powered by a Merc. How much more open minded can one get. Only time will tell whether 4-strokes will be around (untouched) in 20, 30, or even 40 years. I have two 1946 Johnsons neither of which have ever been opened up. I further contend that if you did plot fuel consumption at equal rpm across the board what you will end up doing is looking at the MPH column and saying -- "by golly look how much faster the two stroke engine is pushing the boat at that rpm." Your next comment would be, "well if I cut back the RPMs I would get nearly the same or in some cases better economy than the four stroke." It all boils down to the amount of work being done on the fuel being consumed. Once you make that connection all of this should make a lot more "financial sense". Yes we have a much cleaner burning engine with current technology. But thinking you will make up the cost difference in fuel savings is a stretch for the non-commercial boater.
