Part Number Help
DHPMARINE
Going thru old inventory and came up with a remote control with no part number.Maybe someone can help.
It's definetly OMC and is definetly OLD,as well.
It is white with a chrome handle.The lower part of the handle has a "window" and you can select Forward (fast and slow),Neutral,Start,and Reverse (fast and slow).It has two steel,vinyl-coated cables,about 1/8 diameter.The instruction book indicates the cables go to a "slave" cylinder that does the actual throttle and shift.
I want a part number because being a Johnson dealer, other dealers can access my inventory when looking for parts.Probably the only way to get these parts off the shelf.
DHP
F_R
Re: Part Number Help
You got the 1959 Johnson Accessories Parts book? The control head is part number 377500 for Starboard mount and 377501 for Port mount. The slave is part number 377502.
DHPMARINE
Thanks F R .Actually I forgot to include I can barely make out 500 on the box.I will endevour trying to post pics.
DHP
F_R
Yep, that's it. All three OMC divisions, E/J/Gale offered it under the same part number. Apply sticker as applicable.
They must be pretty rare. I might have seen as many as one.
very cool looking, i've never seen one.
