pennyanman1
- Joined
- Sep 8, 2005
- 30
A week ago, I had two incidents, back to back, of my engine "banging" which I'm now aware may have been the forward gear/clutch dogs slipping. It only happended twice and the motor ran fine afterwards. The motor has only about 150 hours since new and I never "lag" during shifting. I took the gearcase to a local dealer and was told the bill would be around $1400. He explained that my stainless prop puts an excessive load on the clutch dogs, and that is why it failed. He checked the magnet on the lower plug, which came up clean, and the gearlube is nice and clear, looks fresh in fact. He also checked the shift rod height which was perfect by his shop gauge. I'm changing the shift and throttle cables as a precaution, but I'm told that doesn't matter. When the unit is in gear, does cable tension have any influence? I'm thinking since the cables are 10 years old, and the fact that I tightend the thumbscrew on the shift cable two full turns tighter, with no change, that maybe I have a cable problem. Cable at $14.00 vs. lower unit rebuild at $1400.00. I'm PRAYING its' the cable!!!
