Repowering a 25' Tiara Center Console
EastEnder
As the title says, I'm looking to repower my boat (the current info is in my sig). Friends and family that are into boating are tryin to convince me to get a big single outboard instead of twins. My boat was really designed to have twins, but I have seen a few boats like mine (same hull, different deck, ie walkaround, not a CC) that are running a single 225....the boat wieghs about 3700 lbs dry. There are other sister ships running single engine I/Os with just a 350, ie 270 ish hp...Can I get away with just a 250? Who would you recommend for an engine? I'd love a 275 or 300 Etec, but they dont exist yet. Anyone know if they are in the works?
Thanks a lot.
-Tom
Re: Repowering a 25' Tiara Center Console
if you are going off shore, go back with twins. security to get home. going with a single i don't think you will be happy with performance, you are dropping Hp 33%, which would put you at minimum.
cougar1985
twin 225 h.o. e-tec,s would rock!
JB
Yup. Boats designed to use twins need twins.
Security is a given but many overlook the maneuvering advantage of twins.
Dhadley
If it were mine I'd consider a couple of the small block 200 E-Tec's. Just as much power as the old 225 carb'd motors and use a heck of a lot less fuel. Not to mention lighter and quieter.
As for the big E-Tec's -- stay tuned........
EastEnder
Thanks for the input guys, I appreciate it.
I forgot to add this one thing.....the boat came from the factory with a set of v-4 140s, and it ran fine. Most guys repower this rig with a set of 60 degree 150s and it run great. Not a speed demon, but good. The guy who owned the boat before me wanted a lot of speed for going offshore, not to mention he was a bigger fella. Almost twice the size of me. (I'm only 5'7" 160lbs)
As for going offshore....i can see that I'll go maybe 20mi out maybe twice a year...i can exactly afford the gas to do it that much anyways, but I see your argument. But I also know for $100 a year, sea tow will come and snatch me up to 30mi out....I KNOW I'm not tryin to hit the canyons on this thing (the cayons off of LI are 50mi + out) shes a bit small for that.
Big E-tecs coming soon huh....i'll keep a look out.
