Evinrookie
- Joined
- Aug 20, 2007
- 100
Took my 67 80HP Evinrude out for the second time this past weekend and the motor acted way different from the first time out. Here is what changed and how the motor acted.
1st Run
Engine ran great. Idled good. Went very fast at WOT and did very well putting around the lake. Just my wife and I in the boat (approx 350lbs combined). Gas was probably mixed too rich because wasn't sure of ratio at the time and a bunch of unburt 2-cycle dripped out when done.
2nd Run
Ran ok. Idled good. Very good putting around the lake. At a little over 1/2 throttle started to sputter a little. From 3/4 throttle to WOT sounded like it was going to stall until I backed it down. Wife, both parents, and I onboard (approx. 850 lbs). Mixed 50:1. Just a little unburnt 2-cycle coming out. I also changed the LU gear lube but I don't think that would have given me the problem I experienced.
My boat is a 15' Crestliner Tri-Hull and I was pretty much at the weight limit. Would the added weight cause the engine to sputter? I know a carb clean is an obvious next step but I doubt the carb would get gummed up enough in that short amount of time. Is there something I'm missing?
1st Run
2nd Run
