Trailerable trawler
KnottyBuoyz
This isn't my project. But here's an example of a larger scale infused hull composite boat.
"http://picasaweb.google.com/steve.marshall/TrailerTrawlerConstruction"
"http://marshalldesign.blogspot.com/"
It's this sort of large scale infusion that I'm looking at with our project. We hope to start in March if the building facility is available then. We're building a Jacques Mertens 28' trawler in Stitch & Glue ply/glass stretched to 30-1/2'.
Re: Trailerable trawler
top link did not work, when posting it please put the " infront and back" this way you get around the direct link rules. thanks. interesting process. then it is easy enough to just copy and paste.
KnottyBuoyz
Roger that TD. Still learning.
Yes interesting process. Still considering if it's worth the extra $2500 to use foam as a core over marine plywood. Leaning towards the foam.
Rick
drewpster
Incredible, Very cool process. Do they use a resin that has a long cure time? It must take awhile for the resin to flow out such a distance.
KnottyBuoyz
Yup! The stuff I use is ultra low viscosity so it'll flow better and takes about 5 hours before it starts to kick. 24 hours till hard 'nuff to handle. 3 to 5 days till fully cured. You can speed up the process with heat which we've done on small jobs to help control the resin flow.
