'04 Merc 4.3: No spark
Barry5292
Hello,
I have a 2004 Merc 4.3 V6 (carberated). It has been working fine, but now I have a problem. The starter cranks the motor, but it won't turn over. There is good gas in it and the motor seems to be getting gas fine. I tried to see if I had spark at one of the plugs and it appears that I do not. I'd like to troubleshoot this and figure out what's up, but I don't know where to start testing voltages, etc. Any suggestions for a starting place? Thanks!
Barry5292
Re: '04 Merc 4.3: No spark
Hello, Thanks for your help and the link. That is good info, but I think my problem is a bit different. I know I have a starter problem. I get a solenoid click, and if I tap the starter I can get a crank, so I know starter needs repair.
The main problem I want to troubleshoot is when the starter DOES crank, I do not see a spark at the plug. I have removed the wire off the plug, but a screw drive to the wire, and (while holding the insulated handle of the screw driver), crank the engine. The engine cranks, but I do not see a spark from the wire when I hold it close to the engine block (using it as the ground). So I believe that I need to start working my way to the distributer, coil, and whatever else might be the cause. This is where I could use troubleshooting advise similar to the key, solenoid, starter info you pointed me to.
Thanks!
Haut Medoc
Ok, Well, the first thing you need to test is if you are getting 12v at the + side of the coil with the key in the 'run' position....;)​
Barry5292
OK, I'll start there. I appreciate all helpful advise.
Thanks
Haut Medoc
This is what you need?......:)​
Barry5292
Thanks for finding this for me. I'm going to have to get some diagrams to identify all the parts that they mention...hopefully I can reach them also. Some of this stuff may be over my head to identify, but I'll give it a shot this weekend. Thank you again for you help!!
