erikgreen
Thread starter- Joined
- Jan 8, 2007
- 3,105
So, I spent the whole day with a hoist trying to get my recently built 350 GM block into my 1983 Sea Ray SRV210CC. This is the same engine with pics in the "My Rapido Longblock" thread.
The problem I'm having is that while I have the engine on the boat and attached to the transom plate, even though everything seems to be correctly assembled per the Mercruiser manuals (online) and the Seloc one(paper), the alignment tool goes into the gimble bearing and hits the coupler about a quarter inch too low to enter the spline hole.
So it's not a matter yet of adjusting the forward engine mounts.. the alignment tool doesn't even go in the coupler yet.
Here's what we did:
1) Assembled the engine on the hoist - bell housing, starter.
2) Using bolts, fiber washers, and double wound washers off a pair of new mounting kits we aligned the motor to the transom plate and attached the rear bolts. We used tape to make sure the nuts stayed in place until we got the bolts in. We didn't know the glue the fiber washers down until just a few minutes ago.
3) Attempted to insert the alignment tool.
The bell housing is bolted to the transom plate and is sitting about 1/8" or so above it, on top of the fiber washers.
I do have a new set of rear motor mounts, but we couldn't find a reference on installing them, so we didn't try. The old ones looked okay (but what do we know?) although the port side one was a tiny bit lower than the starboard side.
We're stuck (and I just incurred another day's rental charge on my hoist).
Erik
Here's what we did:
Erik
