shipwreck
Thread starter- Joined
- Nov 23, 2006
- 263
1967 EVINRUDE SPORT FOUR 60 HP MODEL 60733
I WRITE ABOUT HEAVY SHAKE OF THE MOTOR, IN LAST WRIT UP.
I SINCE, HAVE CORRECT MANY PROBLEMS
REPLACED CARB GASKET , TURNED DOWN LOW SPEED NEEDLES(adjusted right)
and cleaned up plugs and disturb, points set and gap , lubed Bendix spiral shaft, note this helped the boat start much easy, replaced pack or jam nuts for low speed needles , this made noticeable difference in tightness of needle when be turned, before vary loose. Cleaned all +, - connect connections. pressure checked 90 all cylinders cold motor / not warmed up ...ya 90 psi...
So after all that, run the motor ...
The motor still has a heavy shake will shake to starboard side.
note , when i turn the flywheel by hand clock wise , 180 degrees the is vary little resistance and the other 180 degrees vary stiff.
i work on the thought that all piston are cycled in 360 degree turn of flywheel ?
Is this normal?
The same thing happens when motor's running , sounds good for a couple seconds then drops out like dieing (can keep up) and comes back.
my thoughts: on bad engine running
bad spark wires
bad spark ground ..they have heil coils installed
bad point
I am going to pull all plugs and check to make sure the are all cylinders are getting fuel mix. That should kind help rule carb no fuel problem.
Can lower unit be removed and the engine ran with damage if hook water up to inlet tube?
Is this normal?
bad spark wires
bad point
