Hi,
I have a 2006 BF150A Honda motor on my 2000 21' striper boat ( I just bough it). The motor runs great and the boat is awesome. However the compression on the cylinders has me a bit worried. The compression is a follows:
from top to bottom:
Piston 1 170PSI
Piston 2 160PSI
Piston 3 165PSI
Piston 4 175PSI
Is this normal or should I be concerned? The motor is still under warranty (2011).
Any advice will be appreciated.
Thanks.
from top to bottom:
Piston 1 170PSI
Piston 2 160PSI
Piston 3 165PSI
Piston 4 175PSI
Thanks.
