tjl76evinrude
Thread starter- Joined
- Sep 18, 2007
- 99
hey there. i have a 76 evinrude 25 hp, model 25602e duct taped to my lil 83' indian river boat mfg fiberglass flatbottom.
skippin a long story, it ran great when i got it. it had recently been on consignment at a store/shop before i bought it. they claimed to have replaced a coil, adjusted carb and idle.
the fun started when i found the needle for the bowl was worn and sticking shut. i cleaned the carb and put a rebuild kit into it and it hasnt really been happy since. ive adjusted and cleaned it again a few times. but it wont hold an idle very well and just recently it seems to be missing at higher RPM's.
trying to get on track here,
Is there a idle adjustment screw other then the low speed needle?
i reset the follower for the timing a few times and its happier, then using the tiller limiting screw i brought the idle speed up a little to where it wouldnt stall so quick. its been running decent at higher RPM's then not wanting to idle at all. also the new coil is nice but the old coil is moving around on the metal that bolts to the block. it still functions though.
so the probs are
where is the primary idle control "screw"
after running high RPM's it doesent want to idle
when running at higher rpm's its recently been missing. i was planed up and it choked a few times and almost died.
i just cleaned the screen on the fuel pump and the spark plugs are pretty new..
it seems like it isnt getting enough fuel but if i pump the bulb when its staggering it seems to almost make it worse.
any suggestions?
thanks!
so the probs are
any suggestions?
thanks!
