Re: More power
You may be able to improve your motors performance.
First be sure your motor is in fine tune start with a compression check.
be sure the prop is in good shape.
Then you can fine tune your setup.Be sure the antivent plate is at least even with the bottom of the boat.You can also raise it farther a little at a time with 1/4 in. sticks at the top of the transom.Raise it until just before venting becomes a problem.Be sure clamps still have a good grip and it is pumping water.Depending on where your at now you could gain as much as 2 to 3 mph.Once your set and check your rpm,you can up grade the prop.
Perhaps as simple as adding a little cup to the prop.You can also select a prop for your specific requirements.A prop might let you raise the motor even more.Of course careful weight distribution,motor trim and clearing out excess weight can help too.
