Re: Limp mode
Hi all,
have found the problem, as simple as a sticky choke, there is a manual override lever on the choke linkage that was knocked and bent at some point, intermittently the lever would stop the choke from returning to the off position, it would seem the return spring was also weak and allowing the choke to stay open just enough to cause the problem. The up side is i now have a new fuel pump, oil flow sensor, water flow sensor and a heap more knowledge of how these things work. Thanks to all who gave help and i hope my solution may help others with similar systems.
cheers
BW.
