HELLO
I bought this motor a 6 months ago, when I got it the guy ran it, started on 2nd pull ran fine, I bought it brang it home tryed it on a little aluminum boat ran good but not full out then stopped I had no gas left, I brang it home I mixed oil and gas to 50:1 it won't start anymore not even a puff (all it will do is just back fire when I try to start it) I was looking around the carb to see if I could see anything, I looked I seen gas dripping from the carb on the bottom, I pumped the tank (pressurized) and just started to pour out from a hole on the top and on the bottom, I took the carb apart and seen that the cork float was a dark brown and when I put the carb straight the float just sat on an angle, I hope it can be fixed Can you help..
BRAD
BRAD
