fill some holes
Texasbikers
Hi, I have a few holes I need to fill that are a result of replacing and moving some cleates. Small screw holes that had machine screws in them.
Whats the best way to fill them, the surface is white gelcoat?
Thanks much
gcboat
Re: fill some holes
If you're particular on color matching then you should patch with gel coat. Call your mfg. and ask then for a matching color kit - or where to buy one. If you don't care for an exact match then use this stuff:http://www.marinetex.com/
pgdignan
Re: fill some holes
Marine tex will work great, you could also try a little two part epoxy with some silica thickener or bondo, or kitty hair (if the hole's large enough)
