Oil Pump Pick-up
FreeBeeTony
The Rapido engine comes with a new oil pump w/o the pick -up tube/screen.....the srceen is tack welded on my original pump (which Raul says isn't a badd idea).........when I install a new one should I bother securing it or just press it in?
Re: Oil Pump Pick-up
Ayuh,......... I gotta Agree with Raul again,........ It Ain't a Bad Idea,.....
But not at all Necessary............
I don't knows that I've ever found a Screen bouncing around in the Pan........
FreeBeeTony
hey bondo...........keep an eye on this project if you can......I value your opinion............hope to start reassembly this w/e
Ayuh,..........
Even when I'm not commentin',.... I'ma watchin' yer Back...............;)
rodbolt
braze it or at a minimum epoxy it. I have seen a few fall out, one on a pair of crusaders with less than 20 hours.
crusader did not pay. says it was not their issue.
was a bumer deal.
we always welded/epoxied or otherwise physically secured the pipe to pump.
however if you use the correct installation tool and its a decent press fit it should work.
Bt Doctur
On the oil pump I`d make sure it`s a "standard" pump and not a "hi-volume"
Also had a engine lose a pickup tube .I weld/braze the tube in place.
erikgreen
I just pressed mine into my rapido block.
It took two guys 10 minutes to do it... I don't think I could get it out if I wanted to.
The pumps rapido sent are standard, as far as I can tell.
Erik
Reel Poor
It's not worth the gamble Tony for what a little epoxy or a spot weld cost. I too have seen them in the oil pan on a couple of occasions, never from the factory, both were on remand engines. :(
FreeBeeTony
What type of epoxy is good to use............like a 5 min epoxy in a tube?
MikDee
Banned
Just curious, what's wrong with a high volume pump?
tommays
Tony
i would take it down to a welding shop and have a quick TIG tack done on the tube
Tommays
FreeBeeTony
I purchased the pick-up tube tonight a "pressed" it in............there's no way this is coming loose........don't see a need for any epoxy or welding..........
Going to commence assembly tommorrow from the bottom up............
farmboy
That pressed fit sounds adequate. The TIG or MIG spot weld sounds good also. It has been my experience with any epoxy to metal reinforcement or repair that meticulous surface prep is mandatory. If one reads any epoxy product data sheet it will talk about minimum cleanliness and surface profile. I think the chemical fix is WAY to much work for this job.
Robj
For the piece of mind, I would still tack it in place. That way you know it will never fall out. There is a fair bit of vibration going through that engine and a few have seen them fall out. Just my $0.02.
Have a great day,
Rob.
stinger222
Just got a call yesterday from the guy re-sleeving my block... the pickup tube is laying on the bottom of the pan...Will be welding it this time.
Bt Doctur
For MikDee,
With a "hi-vol" pump you have to increase the volumn of the oil pan.
standard is 4 maybe 5 qts.The motor needs oil pumped from the pan to the engine to work properly,excess oil drips back to the pan to be re-pumped.
A hi-vol pump will drain the oil pan of all the oil and then you will hear some not so funny knocking sounds from a lack of oil supply.At the very least a 10-12 pan to contain enough oil to prevent a failure. Chevy sb`s will almost run forever with 35lbs of oil pressure.
f_inscreenname
I had mine more then "tacked". Didn't want any air leaks you know.
