swap chevy 3 L for 2.5L
Scaaty
Re: swap chevy 3 L for 2.5L
I have no idea what you are talking about...this an MERC outboard?
Post your question on the Mercruiser I/O forum.
whywhyzed
Banned
maybe, and probably, but what year and what make is your powertrain?
Dante04SRT
The swap would be virtually a direct swap, the block is basically the same, so as far as bolting up, it'd be fine.
The only thing I can think of would be the manifold. The 2.5 head has a different port setup than the 3.0. Many will tell you its a direct swap, but I'm not 100% convinced a 3.0 manifold will work on a 2.5 head w/o and problems.
See for yourself the differences:
If your motor is like my 3.0, the riser is curve shaped and not hard angles (like the older 3.0s and 2.5s)... I'm not sure if the 2.5 manifold and 3.0 curved riser will work together... and I'm fairly sure that the standard 2.5 riser won't directly fit the piping meant for the curved riser either; Someone else may know better...
Just trying to help you out - I was in the same 'boat' the last 2 months, looking for parts.
DHPMARINE
I just took a look at 1986 Mercruiser and OMC 2.5/3.0 parts.They each (respectively) take the same manifold and manifold gaskets for either size engine.I'm sure other years would show the same results.
What would concern me is the 20 HP power loss.I'm sure it will be very noticable.That said,sometimes we have to do what we have to do.
DHP
I have a 2.5L chevy, can it be used in place of the 3L?
Ayuh,.......... That Depends........
Is this 2.5l Chevy from a Chevy automobile,..??..??......
If So,.........
Nope,..... It's a Different Block, Different Head,.... Just a Different Motor......
If this 2.5l Chevy originally lived in a Boat,............
Sure it's a Direct Swap..........
