'76 70hp-Driveshaft & Bearing Housing Removal
philobite
Evinrude - The engine seemed to seize suddenly and without warning on the lake yesterday. I was unable to rotate the flywheel. Today I dropped the lower end to check the impeller and discovered that the problem is not in the motor (without the lower end attached, the motor turns just fine), it's in the lower drive unit... the driveshaft will turn in neutral only with great effort using a vice-grip on it.
I'm trying to remove the driveshaft and bearing housing, but after removing the bearing housing bolts (4), I don't seem to be able to get the housing to slide up the driveshaft, or get the driveshaft to come out of the lower unit. The bearing housing will rotate on the shaft with great difficulty (ie, tapping it around with a screwdriver and hammer taps).
I'm purchasing the repair manual, but in the meantime I'd appreciate directions on removal of the driveshaft and the bearing housing.
F_R
Re: '76 70hp-Driveshaft & Bearing Housing Removal
There is an o-ring around the bearing housing which would provide some friction in trying to pull it out. And of course if the bearing is siezed to the shaft it will be really tight to remove.
Either way, you will gain nothing by simply removing the bearing housing. There is a nut on the bottom end of the drive shaft. You have to go in from the prop shaft end to get the nut off.
philobite
F_R: Thank you. That's exactly the wisdom/info I was looking for. Looks like a total tear-down.
