How do I repair hull leak?
Cayo Boater
Hey folks, I need your advice. I have a 14' McKee. It got banged up against the dock in an unexpected storm. It's now on the trailer and after a good rain I noticed a few spots on the hull leaking. I can actually see it dripping on the outside so I know where it is. Is this fixable, and if yes, how is the best way?
JB
Re: How do I repair hull leak?
Is that a 'glass hull? Where are the leaks? Are there cracks visible?
Cayo Boater
Yes, it's fiberglass, and they're visible. There are harirline cracks on the inside area coinciding with the leaks on the outside. What do you think?
Robj
If you can access the area from the inside, I would grind down the damaged area, and the area surrounding it, and lay down some new glass with either polyester or epoxy resin. How much glass to use, I would look at what was there originally and go from there. While I am not an expert, nor have I seen the affected areas, I think it would be a relatively simple repair.
Have a great day,
Rob.
