Hello and thanks for any help
My 1991 Proline 230 w/a 200hp Mariner starts up great and in gear all through the no wake zone is good. As soon as I give it gas to get up on plane the temp goes up just to the point that sets off the alarm.( about 180 I think) alarm goes on and stays on for a few seconds. It then goes off and temp falls back down to 140. After cruising on plane I come down to a crawl and the alarm goes off again. temp rises just to that point again but then comes off the high point and is okay.
I just bought this boat. The PO told me he has not changed the impellor in two years so thats my first clue.
Could it be that the impellor isnt pushing enough water to cool when the engine starts to get hot (Soon as I put it under load) but then the high rpms make it push enough water too cool it down. And when I come off plane the water flow cant cool the hot engine but soon the engine cools and the water flow is enough?
The t stats are new the old ones were covered with sand and gunk.
The compression check was fine and it runs great under load or at idle.
Any suggestions would be appreciated
