elec trouble with old blue band
david watson
i have an old 69 1000(100h.psix) blue band merc mechince.s are fine but wiring is fraded needing new wiring. what i want to no is?would it be worth rewiring it and when it die,s rebuild it (run,s great still 125psi in all 6 cindlers but wiring is failing it) and if it is worth it a kit & a manual to go through it thank you
steelespike
Re: elec trouble with old blue band
You should really be in the Merc section.But with good compression and running good it sure sounds like a good prospect for a refurbish.
tmcalavy
Get some marine grade wire the same gauge as your original wiring. Take your time and replace the frayed wires with the new. Did this on a 73 Merc 500 and it made a world of difference...shouldn't be much harder on your Merc.
D
DJ
Guest
Moving to Mercury/Mariner Repairs and Questions.
ThumbPkr
I agree that the motor is worth saving.I have a '69 and a '70 650 and that era seems to have a had a bad run of wiring.The insulation gets brittle and cracks terribly on them.You can buy new harnesses for them still and also there are some used ones on ebay,presumably they would be made of the same wire that you have which has cracked so I would be careful of anything that fits your engine and is the same age.
If your engine has the original wrap and it has a blue band I suspect it to be newer than a '69.Since it is 100 horsepower it is more likely that the wrap with the blue band is from a newer engine.Yours should be red with a mirrored background.I will send a pic if you need to compare them.Ron G
david watson
yes please my email ad is zoe456@bigpond.com thank you
david watson
And there never was a blue band 100hp. Ever
im only going by what the block said i got it from bbut i took to the shop the other day & the guy there said the same thing but cant remember what he called it but i found a small pin hole in the block lecking water out yesterday so i think it,s another motor if you want i,ll send a pic maybe you could tell me.not happy but runs like a dream.
ThumbPkr
Here are a couple of pics.The two engines in front of my truck are model years '69 and '70.The nearest one is the '69.I am sorry that the quality is not very good.My old Mavica was a great cam in its day.:))
The boat pic was taken years ago so you can see how the colors have faded although a good coat of wax will help bring them back some I am sure.Mercury pretty much stuck with the same color on all of its motors for a given model year.Ron G
david watson
start again new motor
ok i started my merc this morring to see how easy it would start 1st thing in the morring about 5.30am. she had a miss in it so i gave it some rev,s and she throw number 5 conrod cup so any one with a motor about the same h.p (100h.p.h) or higher and how much(glad it happened now not in the water)
OldMercsRule
Hey David, I own two 1969 Merc 1000(s), both short shafts. One is very low hours and nearly perfect engine that I have had for 10 - 12 years the other has only been in the "family" fer 10 months. #1 All 1969s were bright red bands and stated the 1000 or whatever size on the top cover. (That is how to tell a 1969 from a 1968.) #2 I bought the latest engine in Vancouver WA fer $350 in December 2006. It runs great, with even compression, and it had two fuel leaks, (this is normal as the pristine one leaked in the same two locations, as did my 1968 1250), I used factory lines from me silver block parts motors to fix the recent acqusition 1969 1000, and had to buy different brass fittings and build new gas line to fix my other 1969 1000. (I posted the parts #s on this forum). I also changed the wiring harness on the recent purchase, (which it may not have needed but the old one had been spliced and did not look very good). IT RUNS GREAT!
Since yer now lookin' fer another engine, I would try Craigslist. Here in Seattle during the winter a good 1150 or 115 can be had fer $300 to $500, a little more for PT. Ya don't want salty engines, (except as parts engines), as Mercs don't do soooooo good in a Salt Water environment. If yer boat can take 15 more HP, I would prolly look fer a distributer fired black block 1973 or 1974 to 1979, as the single fuel pump and filter is easier to service, and the fuel lines don't have the leaky old brass compression fittings. That said I am always interested in a good running 1967 and up 900, 950,1000, (90 cubic inch)1100, (94 cubic inch),1250 (100 cubic inch) 1150, 1350, 1400, 1500, 90, 115, 140 (all 100 cubic inch) to late 1980s 115, (the same as the 1981 140 and the 1982 and up 90 is the same as the 1981 and earlier 115). I don't like the pre 1967 as ya had to mess with points, (although they would still tempt me). I also favor the distributor fired engines 1979 was still distributor fired, (this maybe irrational fear of the unknown as my son has a 1981 115 that has six coils and it is OK too). The 1979 and up had a speedo pick up in the Lower Unit, (which has a larger gear oil capacity, and a sharper angle on the skeg).
Good luck, My overpriced $.02 JR
