Standard prop 1802wa??
LukeB
The Previuos owner of my boat installed a 4 blade prop. My boat reaches max rpm at about 1/2 throttle according to the mercury 125 hp saltwater specs. It is under propped for sure so what is the standard prop for my boat??
Any help appreciated..
Luke
springhead
Re: Standard prop 1802wa??
luke
ill check my prop in the morning and reply back; its midnight and too late now.
i Have a 2004 1802 with the 125 merc saltwater.
rob711
i'am at work now..i have a 2005 1902 wa w/115 4 stroke merc..i'll check when i get home if this will help
rob711
ok ....i meant 1802..any way i have a 15 pitch prop...thats on a 2005 115hp 4-stroke saltwater series mercury. hope this helps
lyle
lose the 4-blade...those are better for skiffs & such. once you establish the correct pitch put a three blade back on & that will bring your RPM's back down
mole2
I just looked up what prop I had on my 2003 Trophy 1802 when I had it and the prop it came with was a 12.75 x 21 x 3. Since I don't have the boat anymore that's the best I can do for you.
