dschild
Thread starter- Joined
- Sep 23, 2007
- 43
Had this boat for about a month. First boat. It started misfiring about two weeks ago. I have not taken it out since. I found that there was a small leak out the starboard side of the motor coming out of the head cover. I figured water was getting back inside causing the misfire.
I replaced the following:
Head gasket (the one in there turned out to be blown around the 2nd cylinder)
head cover gasket
thermostat gasket
thermostat cover gasket
spark plugs (found out the guy at west marine gave me the wrong ones. Inland marine told me I was to use gapless plugs.
Motor seems to sound a lot better now. But the leak continues. It's not as bad. I torqued the head cover down a little more (beyond recommendations) and it reduced the leak a little. But it is still there.
The leak goes from a drip to a spray as the throttle increases.
I let the engine run for 5 minutes to warm up and see if the leak would stop on its own. No such luck. (But it never misfired. I even popped it in gear and let it run high for 20 seconds)
Any recommendations?
head cover gasket
thermostat gasket
