AGENT 37
Thread starter- Joined
- Mar 2, 2007
- 319
I have just rebuilt my 1999 F100. After reassembling it I have an oil leak running down the driveshaft and splattering out onto the mounting bracket and also have water getting into the oil at higher RPMs. If I let it idle on the muffs for abouT a half hour the oil starts to clear up. When I was reassembling it the manual called for sealant on the crank case mating halves but as far a I could tell only indicated oil on the crank seal/oil ring. So I didn't put any sealant around the outside of the rubber, just on the metal to metal surfaces. I have a feeling that might be where the oil leak is coming from. Any opinions on sealing that up? Any suggestions for the water leak? I had the cylinder head welded and milled down, installed new gaskets, and followed specified torque patterns and values. I pulled the power head and found a little bit of material that I missed, cleaned it and applied a gasket maker to the gasket and reinstalled it without much improvement. I took it back apart and have two fresh gaskets on hand. I would appreciate any tips to help me get this thing fixed. The manual referred to applying a coat of metallic paint to the gasket if the head had un-correctable warpage to help fill in gaps. I'd like to hear ideas either way. Personally I've always gone with what the book says as the standard methods and manufacturer recommendations.
