jack plates...
jimyoung
what are the advantages of a jack plate? I understand lifting a motor to allow a long shaft to be mounted on a short transom.....but what does the backset accomplish?
Esox
Re: jack plates...
The setback adds bow lift and puts the prop in "cleaner" water for better prop efficiency.
steelespike
Re: jack plates...
I believe the jackplate also makes it easier to fine tune the motor height.
jimyoung
Re: jack plates...
Thanks...I will start looking for one ......always to improve performance.
studlymandingo
Re: jack plates...
I can definitely feel the boat being "longer" with the addition of the jack-plate I installed on my center console; it has a 10" setback which definitely changes the angle of thrust. I can raise the motor significantly as well which gave me a couple of m.p.h.​
jimyoung
Re: jack plates...
Studly...when you say.. you can raise the motor more.....the cav plate is still in the water, but now higher than the bottom of the boat?
Re: jack plates...
i just made this one inorder to mount a long shaft. it's only a 3 inch setback, $50.00 total
Dhadley
Re: jack plates...
On every boat there's a "sweet spot" for any given propeller. The setback helps you find that spot. It also, as mentioned, changes the fulcrum point which can add bow lift. Setbacks are anywhere from 3" to 30" or so. Lots of options. The theory is that the further you go back, the higher you can raise the motor. To a point. Walleyehed can tell you what appens when you go too far.
Then there's the advantage of running in shallow water. Most flats boats have hydraulic plates. You can run the plate to extreme heights and get over a flat. Or raise the plate up to take off in shallow water.
Basically lots of options, lots of reasons, lots of styles.
jimyoung
Re: jack plates...
I am understanding now....been around boats all my life but have never delved into the finer points of performance and handling.....Wally.........?
Re: jack plates...
wally got to high to pick up water. you know the rest.
