JustMrWill
Thread starter- Joined
- Aug 12, 2003
- 877
This is my first OB so I am still learning. I have an OEM service manual for it. Been trying to get this motor running...it was free and I only started it up briefly when I first got it a year and a half ago (before my restore project).
If I spray Seafoam Deep Creep into the carbs...and crank it...it will fire up for a few seconds then die. Reving the throttle does nothing to keep it running. After it dies...it won't start without spraying more seafoam.
I have removed the air silencer cover and now have access to the carbs.
Is the carb bowls suppose to fill when I squeeze the primer bulb? I have removed the drain plugs from the carb bowls after priming and nothing came out. Does that mean that there is a blockage in the fuel line?
I haven't tested the fuel pump yet...I am under the assumption that the priming bulb will get enough fuel to the carbs to start it...so I am focusing on that issue first. Once I can get it started and running for more than 5 seconds...then I will tackle any other issues that may arise.
Any suggestions would be appreciated.
Thanks.
-JMW
Thanks.
-JMW
