exhaust coming out here??? DHadley?
Gary H NC
Trying to find out why i'm getting exhaust stains on the upper housing.
Is there a gasket leaking somewhere?
Gary H NC
Re: exhaust coming out here???
bump......anyone?
TerryMSU
I have a 1978 Johnson 35 HP that shows the same thing (on one side only - port side)
TerryMSU
Gary H NC
Thanks Terry,
Been reading the manual looking for a reason why.Kind of sucks having a white engine and it turning black after every run...:rolleyes:
larky
could be an exhuast adapter gasket leaking(but just a quess). check the BRP web site it might give ya an idea
good luck
Gary H NC
Re: exhaust coming out here??? DHadley?
Thanks,I have been looking over the BRP site but not sure what gasket it could be...Maybe Dhadley will chime in on this..
HighTrim
Im no Dhadley, but Ill throw my 2 cents in ;) When you had your lu down last, did you have a look at the exhaust ports? I find that to be a good time to inspect and clean my exhaust. Ensure that the gaskets between the segments are intact and secure. One of the exhaust housing seals may be gone (below the upper inner exhaust housing, or below the lower inner exhaust housing) or the cover to housing seal could be shot.
Gary H NC
Thanks HighTrim, When i had the lower off i did replace the rubber gaskets on the lower exhaust tube.I'm beginning to think being those were in pretty bad shape i have a bad gasket farther up.I wish i would have known what to look for when i had the lower off.This is my first Johnson outboard.The only other outboards i have owned were black..
1730V
"The only other outboards i have owned were black.." You just couldn't see it.
Most likely powerhead to exhaust tower gasket. Not hard to remedy.
HighTrim
Yeah if you replaced the lower exhaust housing seals, Im pretty sure the housing to cover seal is shot, usually if one is gone, the others are too or arent far behind. It is in between the housing covers and the outer exhaust housing.
Gary H NC
Oh joy....:)
will i be able to get to it by just dropping the lower?
Thanks HT!
Gary H NC
These Johnson threads get lost fast...bump
Dhadley
Being a crossflow it could be the powerhead base gasket or the adaptor to mid gasket. Start it up with the lower pan off and see if you can feel any leaks.
Gary H NC
Thanks Dhadley, I will check it out. I hope its not the power head base gasket.
I tried to PM you but your mail box is full..;)
