Compression on my 78 75hp johnson?
OpA28
Around what psi should the compression b on my 75 hp stinger?
iwombat
Re: Compression on my 78 75hp johnson?
That's somewhat of a loaded question with no real definitive answer. You're looking for even numbers across all the cylinders. Pressure gauges vary so much that paying attention to any one particular number isn't the best of advice.
Why are we checking compression?
OpA28
When my boat is sitting at idle n i throttle up it gets power 4 about ten seconds n then slows rite down. I wasnt sure if i was gettin drag from the motor bein 2 low, or i was gettin cavitation, or losin compression.
iwombat
During acceleration is when you're testing the torque of your motor the most. So, if it's got good hole shot, but just can't maintain the speed, I think you're looking at something besides a compression/performance issue.
Best bet is to take a reading and post the results. 100psi or better and you're certainly looking good. 60 or less and you've got some problems. The middle ground may or may not indicate issues depending on gauges, particular motors, and measurement procedures.
Any variation of 10% between cylinders indicates something as well.
OpA28
Yea the only time i get speed is when i go from a dead stop 2 full throttle. If i was 2 slowly throttle up i might get 10 mph at most. The motor never races as if my prop was slippn. the motor itself stays at low rpms as if it was gettin drag. Not really sure where 2 start.
iwombat
Compression check and spark test are certainly the places to start. That whole 10% variance thing is what you're primarily concerned about most of the time with compression checks. Spark test will indicate if you've got a weak spark on one or more cylinders.
OpA28
Thanx 4 the help ill c what the comp. says n go from there.
iwombat
Next question:
Is this a new condition, or has the boat always had this problem. If it's always been there (or new boat to you), Where is the ventilation plate in relation to the keel?
OpA28
This is a new boat 2 me n the problem came with it. The plate is mayb 3" below the keel. the motor is as low as itll go on the bracket. My 1st thought was the motor was 2 low n creating drag but wasnt sure it would make that big of a difference.
iwombat
It'll make a huge difference. Raise the motor until the plate is even or slightly above the keel (1" above is a good starting point).
