1994 Mercury Sport Jet 90HP - Porting for performance?
hckrphil
Since I have my 90HP Mercury Sportjet engine in pieces, I've been reading about porting a 2 stroke for a little boost in performance........
Any tips / tricks / suggestions? stay away from it?
Phil
bgbass.1
Re: 1994 Mercury Sport Jet 90HP - Porting for performance?
stay away
JUSTINTIME
get it to a good shop
most just clean the ports up where the sleeve is pressed it
Frank Acampora
I port older Forces all the time. It's easy and you will gain 5-10 hp per cylinder. This is on 3 cyl engines. On 4 cyl engines, do NOT port the exhaust side.
Buy a dremel with a flex shaft. Buy a 1/8 inch CARBIDE straight bit and a 1/4 inch High Speed Steel triangular bit with 1/8 inch shafts.
Start with the bypass ports. Use the triangular bit to remove aluminum and the Carbide to remove steel liner. First, square the ports, then streamline them by removing aluminum. Shape the inter-port webs like a streamlined airplane wing with the piston side about 1/16 inch thick and the cover side sharp. Remove aluminum from the bottom of the port by angling the bit towards the front of the block. this does not enlarge the port any more, but it eases the airflow path and the piston "thinks" it "sees" a bigger port. Don't be afraid to remove a lot of aluminum. Run the Dremel at medium speed and use cutting oil. If you run at too high a speed, the aluminum will clog the bits.
Work slowly and carefully. I usually do just one set of ports a night. It should take somewhere around 2 hours to port each side--4 hours per cylinder.
Next move on to the exhaust side. do the same, except shape them like square trumpets. After you are finished, slightly chamfer the inside of the ports to help avoid ring catching.
If you are a gambling man, you can try raising the ports by about .060. I have never done it but I understand that it will produce more power. But this power comes at a higher RPM with a loss in torque. In essence, you are changing the engine from an all purpose engine to a racing engine with best performance over 6,000. Even with the ports not raised, in order to gain the most power, you must let the engine rev up. this may involve a racing impeller that will unload the engine a little--kind of like a racing torque converter with a high stall speed. Again, I have never tried them but I have heard that Boyeson reeds will also give a little more power. If you have the rubber coated reed blocks though, I think new reeds will probably not be worth the money.
But after all this, remember that a jet drive only provides about 80% of the thrust of a prop drive. All that work will yeild only about 5 MPH.
Have fun if you decide to do it. Go to Chrysler Crew, join, and go to photos. Go to Frank's boats album and you will see a 3 cyl I ported. You can clearly see the trumpet shaping and squared ports. This was one of my first and my technique has improved a little since then. BTW: After all this, The above assume that your '94 has an old style Force crossflow engine block. If Merc modified it and it has boost ports, or if it is loop charged, then you will not be able to port for more power.
Nate3172
I knew Frank would be all over this post:D Nice work on what you have done by the way Frank.
hckrphil
How would I know if it has boost ports or is "loop charged" ? What does that mean?
Thanks a ton! Waiting approval for the Chrysler Guys :)
hckrphil
Can you port JUST the bypass ports, or do you have to port the exhaust side as well? I just don't want to mess anything up (that could get pricey real quick.
Basically, looking at your pic, you just squared out the bypass ports. Seems pretty straight forward.
Frank Acampora
A regular crossflow engine will have 4 ports on each side of the cylinder with a large baffle in the piston dome. A boost port engine will be like the old Merc "Tower of Power" inline six. It will probably have two bypass ports wrapping around toward the sides of the cylinder and a third port in the center which opens slightly later to "boost" the incoming charge into the combustion chamber. Loop charged engines will have angled ports in various positions and utilize a flat topped piston. Because of the angle of the ports, the incoming gas describes a loop in the cylinder as it sweeps into the combustion chamber--Hence--Loop Charged.
If you look closely at the photo, you can look through the bypass ports and see that I have also squared the exhaust ports. Now, that engine block (75-90 hp Chrysler) when assembled gained 8 MPH from the port work. However, old Chryslers were not as peppy as the newer Forces. Newer Force 90 have a big bore --3.375 versus 3.312 for the Chrysler. Also, the newer ignition has a hotter and more precise spark timing than the old distributor. Even with the port work, that Chrysler engine only produces the same amount of power as my 1990 90 HP Force.
If your engine is the old style block, you don't need to port both bypass and exhaust but of course, porting only the bypass will yeild less of a power gain.
On the three cylinder engines, the crankpins are 120 degrees apart, and exhaust timing is approximately 120 degrees total opening so there is no overlap. You CAN port both bypass and exhaust.
On four cylinder engines (inline) the crankpins are at 90 degrees apart and the ports still have about 120 degrees total opening so there is a 30 degree overlap between cylinders. If you port the exhaust you get increased blowback of exhaust gases into the cylinder, diluting the incoming charge and the engine actually produces less horsepower than stock. To gain anything from exhaust porting on four cylinder engines, you must either baffle the ports to sheild them from backpressure (like the old Merc Tower of Power) or modify the engine so that it has very little exhaust backpressure (Full Race Exhaust Stacks or above the water exhaust--loud and illegal on pleasure boats.)
hckrphil
My engine block actually looks just like the pic of yours I posted up above. So you suggest porting BOTH bypass and exhaust sides?
Looks rather easy....... Do you have to hone out the cylinders AFTER you dremel out the ports?
Phil
Frank Acampora
The slight chamfering on the inside (piston side) of the ports helps to keep rings from catching and removes any burrs you may have raised during porting. Even if the cylinders are in excellent condition, it is always good practice to lightly hone the cylinders to "break" any "glaze" that may have formed and help seat the rings. (The glaze is: the steel tends to work harden from the rings running on it and when re-assembled, the rings will not seal as well.)
