I have a 186 sailfish cc with a 90hp 2s Yamaha [2004]. The prop is a ss Power Tech 13.75 x 13[15YM90SCD3R13s] that gives that acts like 15 pitch prop. The motor is set in the next to the hightest hole so it is sitting higher than the manufacture recommends. He recommends one hole down. The boat runs fine, but if I trim the motor to the highest rpm my water pump sucks air and I loose water pressure. I can get 34 mph at 5200 rpm with the present trim before I loose pressure. If I tim the motor up further I can get 37mph at 5500 rpm. I do not get any cavitation in the present set up. Would I be better off lowering the motor one hole and being able to trim up futher or leave it the way it is now?
Ed
Ed
