I just bought a 1956 15 HP (15016) Evinrude, it looks in great shape, but I do not want to kill it by being stupid. I put in a new impeller, and made sure the water tube is in the grommet on the leg, changed the gear oil and checked over the carb etc. It seems to run hot when I have it running in a barrel. The water pickup is clear, as is the pump tube. I put air through the grommet in the leg, and it comes out of the port on the back. I was wondering how much water should be coming out, and where. Can the head be taken off without pulling the powerhead to check the water passages? It looks like it will clear, but the bottom 2 bolts look hard to get at. Thanks, this is a great forum. Rick
