reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I came across an old boat today, bought it pretty right and on it was an old FD-12 motor, (18hp, circa 1958). It runs pretty decent but has an irratic idle, I do notice some fuel around the top crank seal and it has some 'noticable' play side to side in the crank. It don't knock, and the last owner was still using it regularly. (Even still has a fully functioning pressure tank). Compression is 105/100. I suppose it's seen lots of use over the years, but it still runs decent.
My question is, did these wear the top bearing or was it more common to find a worn crank? I won't be using this much, if at all, but would like to make it 100%.
The worst part is that someone camo painted it, but I suppose it was a pretty decent looking motor before that. It looks pretty clean under the cowl.
Also, should I be able to feel any play in one of these side to side? Its pretty minor but noticable if you really try to feel for side play. If not, what are the chances its just the seal?
(It was sort of a byproduct of the boat purchase, the boat was way too new for this and I have other plans for the boat. My original intent was to part this out, but it looks like it may be a viable motor yet).
