Stern drive inspection
mudmagnet63
I will be looking @ 2 used boats this evening what do I need to look for as far as the stern drives are concerned
Scaaty
Re: Stern drive inspection
Have them loosen the lower drain plug and dribble a little out...clean, ok,...milky..run away. Of course they could have changed out the milky stuff first. And, after ya get whatever, drain anyway, and get new gaskets/orings anyway, and new oil. Check after a few water hours. Not much else ya can do by just looking at it...
mudmagnet63
after the engine is started should it be shifted to check for noise in the bearings
gdombroski
I would make sure shifting is easy and smooth without clunk.
Scaaty
Yep..make sure it attached to a water supply..anyone who wants to fire it up WITHOUT any water, even for a second, is something to walk away from too. Best to get a water test if things look good, and you are serious. Best to post here just what type of outdrive BEFORE buying...some you need to stay FAR away from..(actually if it aint a newer Merc or Volvo...walk)
mudmagnet63
The one I'm most intrested in is a mercruser 3.0 any thoughts
U Rest U Rust
move the drives left to right by hand to check for play. should be no more then an inch or two. if too much play, lots of $$$ to fix
mudmagnet63
On my way out the door to go shopping thank's for the advice
Ayuh,..........
If it says OMC on it Anywhere,........ Run, Don't walk,.....No matter how Cheap,....
