Volvo Penta dies after run
Old Man Paul
I have a Volvo Penta AQ130D. When I start the boat in the driveway everything seems great. I've put new points and condenser in, set the timing at 900 rpm (dwell meter).
When I go to the lake it starts right up and runs great. Once I get going and the engine has run for 10 minutes or so it dies as I throttle down and stop. Then it is very hard to start but once started it runs pretty good until I run it awhile. Then the same thing all over again.
Any ideas.....Thanks a bunch
Haut Medoc
Re: Volvo Penta dies after run
Welcome to iboats......:)
Fuel delivery issue......
Sounds like a plugged tank vent or clogged pickup screen in the tank........;)
Old Man Paul
Thanks guys,
I have water seperation filter on the fuel line. It may be in need of changing. It's cheap and easy. I will try it first and give some feedback.
Haut Medoc
By all means do so.....
Empty the filter into a clear container & see what it looks like......;)
Hitech
I have the exact same problem. Auto mechanic friends also think it is a fuel delivery problem. Thanks for those links. I'm off to learn something... :D
