85_celebrity
Thread starter- Joined
- Oct 2, 2007
- 28
I have a 1985 Celebrity 190 BR with a mercruiser 260 Alpha 1 with a 350 chevy motor that I bought used this spring. I have gone through and done all the tune up stuff(plug, wires, cap, rotor, changed all the filters and set the timing per manual spec)When I bought the boat it was very well taken care of but as with any boat this old has a few little problems to address. Ever since the first time out with the boat it has been a bit slugish. The boat weighs 2650 dry and may have another 1000lbs of people and gear on it during normal use. When I say sluggish I mean it won't rev past 3000-3200 rpm no matter what I do. The boat had a new carb put on it about a month before I bought it but it will not come into adjustment not matter who messes with it and backfires occasionally when applying the throttle off of idle. Every time we put the boat in the water I have to take a little bit of fuel and fill the float bowls up with fuel because the are bone dry. The boat seems to run decent but I think that it should run a bit faster than 35mph and also should turn more than 3200 rpm. I have talked with other people with similar boats with the same engine outdrive combo and the are running in the 50+ mph range with more weight on board and running a 13x21 prop. That prop size seems a little small. The boat had a 15x19 prop on it when I bought it and have tried a 14x19 and picked up 200 rpm but no speed. I am looking for ideas that maybe causing the boat to be sluggish. I am also considering replacing the intake with an Edelbrock 2101 intake and either a 1409 or 1410 carb depending suggestions. I may also put a small marine cam in it and have the heads freshened up and gasket matched. I use the boat primarily for buzzing around the lake with the occasional fishing and tubing. Sorry if my first post is rambling and lengthy but the season is drawing to a close and I would like to save some pennies over the winter for repairs on the boat if need be. I cant seem to find any info on the MFG. of this boat because they have changed hands many times in the past few years. I would also love to find some interior pictures of the boat someplace so I can have the seats replace with the proper seats and not these crappy plastic based seats. I guess my questions are shouldn't it rev higher? Shouldn't the MPH be higher? Why do I have to fill the carb up with fuel before starting it after sitting for more than a day or so? What prop would be best suited for this boat. And, Are the mods I have planned going to make a seat of the pants difference. I am pretty convinced about changing the carb, doing away with the quadrajet and stepping up to either a holly or an edelbrock. Thanks in advance.
