mercruiser 260 help
85_celebrity
Re: mercruiser 260 help
Ok I pulled the anti-siphon valve off and tried to blow through it. I can blow through it but I have to blow really hard to get any air to flow through it and it also makes a shuttering noise while I blow through it. Does this sound normal and if it isn't normal where can i go about getting one of these?
Thanks so much guys this would have had me on the verge of selling the boat if it wasn't for you help.
Haut Medoc
"Hard" is a subjective term......
It does sound like it needs to be replaced though......;)​
85_celebrity
where can i obtain one of these. I looked on boaters world and didnt see one. Is this something that i could just go to a parts store and pick up or is a marine specialty fitting?
1730V
The anti siphon valve is a marine part. Boat dealers should have them. You can run without it for TESTING.
You have an air leak somewhere. Your carb should not drain.
85_celebrity
Ok I have looked all over and cannot find the valve at any of the local marine supply places that are local. we have a boater's world and an overton's within driving distance but no marina that I can find. i have looked all over the internet and found what i think is the right part ( tempo part number 260030) but I can't seem to find anyplace where it isn't back ordered. If anyone knows where I can find this please help.
180shabah
An anti-siphon valve that is clogged and does not seal, will allow gravity draining of your fuel system back into the tank.
85_celebrity
I am sorry, I am very new to this forum and didn't see the headings for parts.
Don S
The purpose of the anti siphon valve is NOT (NOTICE, I said NOT) to prevent gas from your fuel system from going back into the tank. That is the purpose of the check valves in the fuel pump.
There seems to be a lot of misconceptions out there of what the ANTI SIPHON valve is for. Most are wrong. It's ONLY purpose is to prevent gas from siphoning out of the tank and into the bilge should something go wrong.
85_celebrity
I went ahead and ordered a new one it may not be the cause but the way I look at it the boat is 20+ years old a new part is not going to hurt it.
85_celebrity
Oh yeah BTW I have a question about the fuel test DonS recommends. First the snap on gauge the you refer to is for EFI and I have a carb set up didnt know if it would make a difference. Also there is and unused port on the water separator and i was wondering if I could tap in to that.
Don S
AKA: Throw money at it, and hope for the best.
85_celebrity
No I definitely don't just throw money at it and hope for the best, but this fitting looks a little rough and it was less than $20 so replacing it isn't a big deal and is one less thing to break later on. I did have to order it so it is going to take a few days to get here can i just find a brass fitting like it and use it or will it cause imminent death?
180shabah
I understand the purpose of the valve, but it doesn't know what it is SUPOSED to do. It just closes when there is no vacuum. Gravity don't care if the fuel line is going down to the bilge or up to the carb. If the A/S valve doesn't close, fuel will flow.
For the record, I don't think this is causing his problem, but he asked how where it was and how to ID it.
wire2
I am pretty convinced about changing the carb, doing away with the quadrajet and stepping up to either a holly or an edelbrock.
"...stepping up..."?
You seem to be down on Q-jet for some reason?
Mine has been extremely reliable for many years. The 7/8" primaries give very good efficiency at low to mid power range, the 2?" secondaries bring on the hole shot.
If yours has a hose barb with a clear tube going back to the fuel pump, it is a marine carb.
I have a very similar set up, a Glastron 19 ft bowrider with 5.7/260. I turn a 14? x 21 stainless for high 50's with 2 people & gear in boat.
If you've verified proper fuel pump pressure, I'd be inclined to briefly experiment with ignition timing under load. With engine cover off, mark the position and loosen the distributer clamp a bit, and have someone drive it while you adjust a few degrees both ways. You'll know instantly if that's an issue.
85_celebrity
I haven't had good luck with Q-jets on cars before and this one on my boat is giving me fits. I want to switch it to something I am a bit more familiar with, that is the main reason i want to go with a holley or a edelbrock. I don't see any clear tube coming from the carb, I know I ask this a lot but I maybe missing it so where exactly is it?
I am going to perform the tests that DonS recommends as soon as I can get a definitive answer about the gauge the I need to get or borrow.
We have tried messing with the timing while under load and it didn't seem to make any difference. What are the chances that this boat is just simply overpropped?
Haut Medoc
If you can't get the proper WOT out of that engine with a 14x19, then something is amiss.....
14x19 is not overpropped for that engine....;)
