1994 Yamaha 200 saltwater series rough idle
whitepursuit2150
I have a 1994 pursuit 2150 with a 1994 200hp yamaha saltwater series motor. The motor has been running great since i rebuilt the carbs and changed the plugs 4 months ago. I use the boat 1-2x weekly. recently (this week) the motor started running rough at idle, with the powerhead shaking a lot. I have also noticed a film of oil/gas on the water when I am sitting still with the motor running. I dont really have any problems starting the motor. After I motor up to around 2500rpm-->wide open, the symptoms disappear. I am currently undecided between a cracked plug, bad plug wire, timing being off, or low rpm coil pak going bad. Any feedback?
Thanks!
njohnson1960
Re: 1994 Yamaha 200 saltwater series rough idle
You have ethanol in your gas? I will not fill up any more without adding STARTRON. My 115 Yamaha was running really rough at idle I had to rebuild Fuel Pump and Carbs last year because of the algae growth issue. I added STARTRON and the engine has never run better since it was new in 2003.
whitepursuit2150
No, no ethanol. I am in Florida, and the stations that use E85 have it pretty well marked.
Ray Neudecker
Did you replace the fuel pumps?
whitepursuit2150
No, I didn't think about replacing the fuel pump. Do you think that may be the problem, even though the high RPM's aren't affected?
Ray Neudecker
The symptoms of rough idle and oil and fuel in the water indicate a stuck needle or leaking fuel pump. Basically, I have found that if fire is there at any check point that an electrical problem is very unlikely on those models.
