Re: Pull Cord Won't Retract!!
It probably means the spring has come loose or the end is broken off. If you have the manual very easy to take off and check and repair, If your need to replace still very easy. Either way make sure you read the saftey information as if you let the spring get loose can cut hands. Also possible the pull cord if frayed and getting caught.
