1955 15hp johnyrude update
gins331
Well put new coils,points set at .20,condensers,rebuilt carb last nite,have new water pump kit ,have not replaced yet but you know a kid with new toy wanted to start in garbage can of water, shes got fuel in glass bowl under carb used starting fuild to bump her she almost starts but shes runs for a few seconds then dies,I have mix screws at 1 1/2 turns any tips to get her to stay runnin my arm is killing me pullin it over and its gonna be 86 here today,plan on changen her over to minuki fuel pump and do away with presure tank thanks for any info Brian
JB
Re: 1955 15hp johnyrude update
Avoid starting fluid in a 2 stroke, Brian. No lube is an invitation to a blown up engine. Use premix (24:1).
Your engine is not getting fuel. Probably a failed carb cleaning.
F_R
Neither a fuel pump or pressure tank system has a dang thing to do with getting a motor started. With either system, you fill the carburetor's float bowl by operating a primer pump, whether it be a squeeze bulb or the primer pump in a pressure tank. Up to now, I am assuming the primer pump is actually working and pumping gas into the carburetor. With the carb full, it should start and run awhile till the fuel in the carb is all consumed, even if you had no tank connected at all. Taking it one step further, if it starts and runs till the bowl runs out of fuel, then starts to die, you should be able to keep it going with the primer pump. If you can do that, then is the time to look for a tank problem, not holding air or the motor not pushing air into the tank.
wbeaton
Is your high speed jet at 1.5 turns too? Should be 1 turn. 1.5 turns on the high might flood it at start up, but I don't think that's your problem. You should revisit the carb. Did you remove the welsh plug from above the low speed needle? There are holes in there that need to be cleaned out.
Also, there is no need to replace the tank. The pressure tank system works fine.
tmcalavy
Sounds like it's primed to run...set the high speed, bottom, needle at 3/4 to 1 turn out from lightly seated; the top needle at 1 and 1/4 turn out from seated. When I start my 58 18 hp or my 56 15 hp I crank the throttle over to Fast, pull the choke out, squeeze the bulb till I know the carb is full and it only takes 3-4 pulls for it to pop over. Then push the choke in and another pull has it going...let it warm up for a few seconds and then throttle down to Start and/or Slow. They need clean carbs though. Either fuel systems works good...just depends on which you prefer. I converted both of mine to fuel pumps so I could use the existing modern tanks/lines I had lying around the shop. The most fun part of these old J's is replacing seals in the lower end and changing the shift connector...definitely learning experiences. Great motors though, lots of grunt and very reliable.
gins331
Thanks all for info, I think my problem is in my presure tank, cuz when I was pushing on primer pump it got real hard like it did not want to work,dont think carb is at fault tore it down cleaned out and blew everything,jet needle valve and double checked all other passage ways to make sure air passed through,I think all I saw was fuel in glass bowl on bottom of carb and was not able to keep pushing fuel in line to fill up in float bowl, gonna convert to fuel pump to upgrade fuel system, hope that duz the trick so she will run great for me next year Brian
sticl small nail or the like in the gas side of the fuel connector on the tank, then pump the button, if gas comes out it is fine. use it. let the tank sit in the sun for a little while, the slowly open the cap, if it hisses, it is holding pressure, and should work
gins331
She squirts and hisses alright, I only have about 1/4 gal in tank think thats enough? I had to shake it around to get it to pump
need more, hard to pick up.
gins331
Gonna try again tomorrow to freakin hot today to mess with let you know how it works I will put couple more gallons in and try, probably my fault for not enough fuel in tank to start with thanks
jbjennings
When you get the darn thing fixed, how 'bout posting a pic of it running on my thread? --would like to see it! I'd try to help but if the guys that have already posted you can't help----NOBODY can!
Hope you get 'er running,
JBJ
gins331
How do you send pics here,dont know how to attach file its not like email easy?
jbjennings
HA HA!-- I just learned that myself.....Just click on the paperclip icon just above your message, click browse to find your pic, and so forth. Hope you get one of that 15 running---have 'ya fixed it yet?
JBJ
