cant control at top speed
rooster1
i have 16 FT V HULL WITH A 35 HP MOTOR I JUST TRYED THE MOTOR OUT TODAY AND AT TOP SPEED I CANT CONTROL THE STEERING ITS ALL OVER THE PLACE WHATS GOING ON THERES A LITTLE PLAY IN MY STEERING BETWEEN THE STEERING WHEEL AND THE MOTOR IM WONDERING IF THATS IT ANY IDEAS?
Re: cant control at top speed
If there is slack in the steering that's very likely the reason you have a steering issue. Ensure the nut is tight where the cable enters the tilt tube on the engine.
rooster1
I Think The Motor Was Going Back And Forth As I Was Trying To Control It Ill Have To Snug It All Up And Try Again Ty
what year motor, type of steering, old cable pulley?
rooster1
ita a 89 evinrude 35 hp had the old pulleys still in there but theres a single black cable now also theres three holes on the motor i hooked the cable to the middle hole is there suspose to be a bracket there?
it should be connect similar to this, thru the tilt tube, then with a connecting arm back to the motor. you have to have the correct connecting arm for the motor.
rooster1
oh me i have a mess looks nothing like that i have the end of the rod going straight to the motor and a bolt holding the threaded part to the transome someone else had it rigged i think the cable is to short to connect like yours thanks for the pick i see now
Gary H NC
Sounds very dangerous!! It must go through the tilt tube.
rooster1
i dont have any idea never had a boat this was the way it was when i got it didnt think it was a big deal why is it dangerous also i dont have tilt or trim on this boat i just let the motor all the way down is this correct? do i have to have bolts through the motor into the transome
thrasher
Any chance you can share some photo's so we can see what you are dealing with?
Gary
