erikgreen
- Joined
- Jan 8, 2007
- 3,105
Hi guys -
I'm just getting started with my new engine. Boat is a 21 foot 1983 sea ray with a reman chevy 350, 4 bbl intake/carb on it, pre-alpha drive.
I took it out to the lake for shakedown and after a couple hours of driving I did a couple WOT runs. Prop was a 17 pitch three blade. I got up to 4000 RPM WOT, dunno speed since I didn't have a GPS with, but the other boat said he estimated 35-ish from his gps.
I then pulled my first stupid human trick (ok, maybe not first) on the way out and dinged a blade of the prop on the ramp pulling the boat.
What I'm wondering is where I should start for prop tuning.. I need to buy another prop for a backup anyway (and repair this one) and I'm wondering if I should use a lower pitch prop to get my WOT rpm or if I should be able to try something higher?
From what I know from reading here, a chevy 350 4bbl in a 21 foot boat should use something like a 19 pitch prop? Yet my RPMs would suggest I drop back to a 14 or 15? Obviously I still need to check on the other causes of low RPM, and I'm working off Don's checklist.
What prop do you think I should order?
Edit: NADA lists the boat weight at 3440 lbs.
Erik
Erik
