I have a limited knowledge but I am willing to try. I am using a clymers book
The engine was hard starting all summer. I thought it was a fuel problem because the engine would eventually start. Now I have no spark at all (all cylinders). I have been all over the message boards reviewing everybodies comments. I have tried the following.
Jumped red lead from battery to black and yellow wire on selenoid no luck.
Removed Bk/Yl wire from key switch no spark
Checked ohm reading from stator wire 2 sets of Br wires(plug connection) leading into power pack showed reading of 930 on both sets
I however get no readings at all on the 2 sets of 4 wire (A,B,C,and D) plugs from the timer base (I think) into the power pack.
I looked at the stator, black square in the front seems to be leaking or melted a bit.
I do not have a DVA to test voltage. Can it be tested with a regular meter. Should I just get a new timer base and stator it about $500 for both. What additional test should I conduct. Compression on cylinders 85 x 5 and one 70.
