Motor mounting Question
2sunaz
I recently acquired a 9' inflatable and a Yamaha 4hp 4 cycle motor. The motor is a long shaft.
My question is; In reference to the bottom of the boat, how low should the prop be in the water for optimum performance?
j442w30
Re: Motor mounting Question
The anti-ventilation plate (horizontal plate just above the propeller) should be even with the bottom of the boat or 1-2 inches higher. This is something that takes some experimenting to find out which setting works best. Whats the length (from top to bottom) of the transom on your boat?
2sunaz
My transom is 16" and the motor measures 21" from the top of the mount to the anti-ventilation plate. Hmmm....
It seemed to work well out in the swells and along the coast, but I kept thinking the prop was too low in the water. I have it trimmed all the way in. The GPS speeds ranged from 5mph-7mph which is about what I expected with full load and two people. But I'm really wanting to see what happens if I can raise the motor 5 inches.......
Thanks for the quick reply, you made me run outside and measure everything!
By Gosh!
2sunaz
San Carlos, Mex
