Alabama Basser
- Joined
- Oct 9, 2007
- 1
I have a 98 Sea Ray SD 240 with a Mercruiser/5.0 litre. The Trim and tilt is intermittent. When it quits both trim and trailer switches on the controls are intermittent - mostly dead. I followed a troubleshooting guide to narrow down the problem. Jumping hot to Blue and Green leads on the pump works. Jumping 2 pins on the connector coming off pump works one time, the next time no. Should I just change out the solonoid first since they are fairly cheap anyway and go from there? Or does it sound like a switch problem. How likely are the trim and trailer switches to both be bad? Are they connected together in the control handle?
